Octavia 1, 2, 3, 4
Tak už má někdo reálně 4ku v používání? Já mám výrobu až konec srpna
-> jerrom: Technical product information 204062012
CopyrighVt W AG
Technical Service Handbook
VIN:T MBAG7NE7F0082603 Modeyt ear:2 O1S
Sales code: 5E34L5
Engine code. CHPA
Registration umber:
Usernamee: rwin
Modeld escriptionO. CTAVIAE LE TS103/1.4MGF
Gearbox code: QSZ
Final drive code.
Service advisor name:
Page 1 of I
Basic filtering of vehicle description
Brartd Modelyear Sales modet Engine code Gearbox code Finat drive code
C 2015 SEo/-o Octavia ilt CHPA eSZ %
Technicalp roduct information TransactioNno .:2 040620/2
Noisesw hilei dling Reteasdea te3: 0_oct_2s0i
Customer statement / workshop findings
. Knockings oundsa t idles peed.
. Noisesc ome to a stop after depressingt he clutchp edal( to the floor).
Technicabl ackground
' Insufficientdlyim ensionecdl utchd isc.T he noisesa re causedb y the preliminardya mper of the clutch
disc,w hichd oesn ote ntirelyd ampent he vibrationfsr omt he engineT. hev ibrationas ie transferretdo
the gearboxw heret he movabrep arts begint o vibrater esurtingin a knockings ound.
. Thisa pplies- in combinatiown ith the manualg earbox- onlyt o engines:
1.4 TSt / 103 kw
Productiocnh ange
Measure
. Replace the clutch set of the vehicle.
. Ordert he newc lutchs et in accordancew itht he enginet ype.
Warrantya ccountingin structions
Fault code / svmptom:
3056 / 0020
Workinq position:
3050 1950 TUs according to current Catalogue of Working positions
Parts information
nqrne Clutch set part No.
14TSt /103kW 14E141 016 KX
https:/ierwin'skoda-auto. czlerwin/rplelsaweb/ctrlTP ldisplayContent/sr1c6/391/ m/9a8s1te ...1 2114/2015
CopyrighVt W AG
Sales code: 5E34L5
Engine code. CHPA
Registration umber:
Usernamee: rwin
Gearbox code: QSZ
Final drive code.
Page 1 of I
1.4 TSt / 103 kw
Productiocnh ange
Measure
3056 / 0020
Workinq position:
Parts information
Ahoj,
kamarád řeší nějaké pazvuky u Octavia a narazil na tuto diskuzi na skodahome, nedaří se mu to registrovat, mě taky (hlásí mi to, že nemám oprávnění k vytvoření nového účtu
) , aby stáhnul pdf dokument, který je zhruba v polovině stránky CLUTCH NOISE AT IDLE.PDF, dokázal by to někdo stáhnout, kdo má funkční registraci a poslat mi to prosím do mailu v kartě?
Díky moc
forum.skodahome.cz/topic/ 131821-pazvuky-z-oblasti-s pojky-14-tsi
Díky moc
-> Milan 136 28.04.21 16:39:12: na b6 sedana?
Dle ETKY Octavia 2,Superb 2.
Rozměrově to vleze do každé nápravy týhle platformy.
Barevné označení viz foto.
Nevyužil by je někdo za symbolickou cenu?
-> Nwkt: Mikulov už je dost z ruky... To je tak hoďka+ cesta, musel bych jet 2x tam a pak dom, nebo tam dlouho čekat... Díky za nabídku, ale už to nebudu hrotit...
-> Jumbo: V Mikulově bych věděl o jednom co tohle dělá, ale otázka tvých preferencí no
-> Nwkt: Mám v jednom autorizáku velmi dobré vztahy, navíc nemám rád, když se v tom vrtá nekdo jiný a jiný prověřený servis tady v okolí nemám... Vím, že to bude dražší, ale když si to auto vyzvedne před barákem nebo u ženy před prací a zase ho vrátí bez nějakých příplatků a starostí pro mě, tak nemám co řešit...
Edit: Tak v autorizáku sklo o 2000 dražší, ale prý by se do toho jejich elektrikář nepouštěl, že to ještě nedělali... Tak na to asi kašlu, to radši nechám ženu škrábat, než to takhle komplikovat... Navíc je to investice dalších tak 6000, což už smysl nemá...
-> Jumbo: Na škodovku nevím, na Passate je rozdíl asi 1500 ale mimo autorizák. Tam bych to asi nedával, pokud nemáš pojistku
-> Nwkt: Jo takhle, takže kabeláž pod palubovkou je, je nutné pouze doplnit kabeláž kolem okna... No tak uvidíme, zeptám se ve Škodovce, co by za to chtěli oproti normální výměně skla, práce na tom asi o moc víc nebude, otázka je, o kolik víc bude stát to sklo...
Díky za info
Díky za info
-> Jumbo: Ne, okno má kostru nahoře pod šroubem lampičky - to udělají při výměně okna a plus je vyvedený v každém rohu u torpéda jsou jsou stěrače. Kabeláž s relé je v motoru, akorát se protáhne jeden kablík na aktivaci průchodkou do jednotky nad pedálama.
-> Nwkt: Pokud tam kabeláž není, tak to by asi musela palubka ven, že? Nebo se tam dá nějak dostat i s palubkou na místě?
-> Jumbo: žádný přípravy nejsou. Nicméně kabeláž se dá sehnat do 2tis. a panel vyloženě nutně nepotřebuješ, můžeš aktivaci zapojit na zadní okno. Ale výměna panelu je nejčistší řešení
Pánové, nevíte jestli má Yeti předface už nachystanou kabeláž na výhřev čelního okna? Včera jsem potkal kamínek, s klidem jel domu s tím, že to "půjde na pojišťovnu" abych pak zjistil, že čelní sklo nějakou záhadou pojištěné nemám... Tak přemýšlím, jestli když už to budu měnit za svoje, jestli tam rovnou nedat vyhřívané čelní sklo.
Je mi jasné, že bych musel vyměnit jednotku ovládání klimatizace za 3T0907044BJ, kde je odpovídající tlačítko, ta se dá sehnat použitá na netu za rozumné peníze, ale nevím co dál by mohlo být potřeba, aby to fungovalo...
Samozřejmě nové okno už do pojistky půjde okamžitě...
-> Jarda:
Ahoj - asi nebyla - to nemůžu vědět :), jen v servisní příručce se to zmiňuje, že ta varianta pružin nejspíš existuje + info o barevném značení.
Ale třeba jak říká SO545, Colin Chapman edt. .. :):)
-> Jarda: Taky jsem se trochu zakuckal, když jsem to četl.
-> Jakub M. 16.04.21 11:24:04: 1.8t RS byla i bez klimy?
to bych teda necekal...
-> Billislav: řešil jsem párkrát B a prošoupaná kabeláž
Zdravim,ak by nahodou niekto mal skusenost,a vedel poradit,na Octavii 2,1.9TDI 77kW BKC v pamati zavad neustale P0698 Sensor Reference Voltage C Circuit Low,neriesil uz uspesne niekto,ak ano,aka bola pricina? Dakujem
-> TTomas:
Pokud jdou ještě sehnat origo nebo economy tlumiče, můžu doporučit přestavbu na origo sportovní podvozek. Pružiny se také ještě občas objeví např. bazoš atd. - stačí kontrola barevného značení a volné délky dle dílenské příručky (snad si dobře pamatuji, že tam ty údaje jsou) - pak máš celkem slušnou jistotu, že budou dobré. Na své 1.8t jsem udělal postupně tlumiče, pružiny, silentbloky v na předku S3, uložení předních tlumičů Leon cupra R. Zadní silentbloky Fab RS.. Auto velmi příjemně ztuhlo. Troufnu si říct , že výsledek je příjemnější na denní ježdění než celé kity B6 Bilstein.. nebo různé podobné “univerzálnější” sady. U téhle anabáze jsem mj. zjistil, že ti škodováci pečlivě ladili pružiny dle hmotnosti auta. Např. Jen na liftback 1,8t Rs jsou myslím dvě sady pružin (předek - s klimou/bez a zadní pro tažné a bez). Byl to jeden z důvodů proč jsem nepoužil výše uvedené kity. Pak při porovnání tohoto “set-up-u” s Bilstein B6 se mi potvrdila ona jakási lepší jezditelnost, použitelnost.
Cena této přestavby byla cca 15tkč v dílech, před asi čtyřmi lety.
Já mám KYB na předku na 900NG a fakt je to tvrdý fest. Ale se sérií nemám srovnání (a už nejde koupit
-> palinator: Hele na komplet Kayabach a jeste se zvysenym podvozkem coz taky jeste trochu pritvrdilo mi to neprislo nijak hrozny. Je teda pravda ze mechos nadaval jak v tom muzu jezdit, ze je to jak trakar ale treba ted Astra mi prijde oproti Ovci asi tak 4x horsi a to je na seriovym podvozku a citim kazdou nerovnost. To v Octave nebylo.
-> moucan:
Ale někdo jinej tu zas řikal že jsou tvrdý jak kámen.
-> TTomas: Za mě bych dal Kayaby. Jezdil jsem je na OI 3 roky a bez problému. Co mi říkali kluci servisáci tak s nima nebyly problémy. Cena myslim přiměřená.
-> TTomas: Moje zkušenost že B4 vytekli po pár tisících, ale jak na tom budou B12 nevím
Nastal čas na další kolo oprav na OI. Rád bych dal i komplet tlumiče s pružinama. Pokukuju po Bilstein B12. Někdo nějaký zkušenosti případně umí je někdo nějak šikovně?
-> Sita 09.04.21 09:43:27: to nejsou díly na škodovku
-> Sita: Ty jo, já myslel "paní na kase povídala", ale tvoje čtení je teda o dost lepší
-> Sita:
-> dragon_cb_cz: PnKP==Poprosit nejakou Kundu Prekupnickou?
-> King 09.04.21 07:57:04: Něco takového, ale zatím je to v rovině JPP. Uvidíme jestli zafunguje to co mi tam dají, pokud ne, bude to muset přejít do roviny PnKP...
-> dragon_cb_cz 08.04.21 09:12:24: Chapu to spravne, ze origo alfí termostat je za sedmicku?
A ja mel do tedka za vrchol zmrdstvi original bmw termostatu na tu moji plecici za hrisnejch 2400 + egr termostat za meco pres litr.
-> StepaNoFUN: Nepředpokládám
Ale znáš to, podobný místa přímo vybízejí k tomu "čekej nečekané"
-> dragon_cb_cz: Myslíš že by byli tak akční a chdili x kilometrů na procházky? To bych u nich nepředpokládal. Tam byly fakt desítky kilometrů "mrtvejch" silnic, kde projelo jedno auto za tejden a to jště jen těch lidí, co to tam znali...
-> vhml 08.04.21 22:43:14: Tak bacha ať v zimě nesbíráš Mongoly s krabicákem jak v létě komáry - na nárazník a čelní sklo
-> vhml: Aha. Myslel jsem že si po čase budu muset udělat vejlet, abych si na to město opravil názor. Jak popisuješ nemusím. :-D Počkám ještě dalších 20let. Třeba v důchodu...
Viz EDIT: No tenkrát to byly vcelku pěkný RZ a provoz se rovnal nule... :-)
-> StepaNoFUN 08.04.21 22:38:29: no tak hnusný je to furt, jen místo mrtvýho se tam potulujou mongolové s krabicákem.
Ale ten vojenskej prostor je vlastně dobrej nápad, na zimní výlet s Miatou :-)
-> vhml: No já si to tam tenkrát pamatuju skoro jako město duchů. Nikde nikdo a nic. Hnusnější a mrtvější město jsem snad nezažil. Byl jsem tam tenkrát na návštěvě na prodlouženej víkend.
Do "bunkru" mi "domorodcema" bylo zákázáno lízt, protože byla prej po pokusu o odstřel nestabilní... Tak jsem tam alespoň jezdil "RZ" (ještě se 742) po tom bejvalým vojenským areálu. :-D A že tam těch cest bylo... :-)
-> StepaNoFUN 08.04.21 19:52:28: tak tam vsude jsou ted zabydleny mongolove a jedna fabrika vedle druhy. Nahoře na kopci je pro změnu satelitní městečko novostaveb pro "plzeňáky".
Jenom nová hala Evobusu má nějakých 300x150 metrů.
-> Syny: Tam někde něco vyráběj? Když jsem tam byl naposled (je fakt, že cca 20 let zpátky), tak tam bylo mrtvo, pusto prázdno a vybydlený baráky po armádě. A pár relativně zachovalejch paneláků, ve kterejch kdysi bydleli důstojníci...
-> Nwkt: Asi myslel Holysov :)
-> vhml: Kde to dělají? Nemáš nějaký zdroj?
-> vhml: jj vyrábí se to v cz. Možná vy dostal bokem i bez vydrapanyho vw znaku
a že jim to musí dát práce
-> saskyn2 08.04.21 08:53:23: to má nejsnažší si pro to dojet těch 15km do fabriky
-> saskyn2: Jsem rád, že tuhle značku doporučuješ, protože se mi jí chystají dát do Alfy (údajně by to taky měl být origo výrobce). Další varianta by bylo origo za nějakých bratru asi 7 tisíc a to se mi teda úplně nechce
-> Syny: vzhledem k tomu jaká je to práce tak bych moc nešpekuloval. Kup Mahle Behr, to je originál, jen to má vybroušený znaky
Jinak se poptam tady :) Vsude se chvali termostat od Wahleru, ale co treba takovy Febi, to je blby?
